If I'm using a widebandsensor and set the gauge for gasoline,
I'm then running the car on e85, what AFR`s should i be having at idle/start to boost, and full boost ?
Basically when running like that you would target a similar AFR on E85 as if you were on Gasoline. (Obvioulsy also denpendent on the setup and what you're using it for etc)
As a starting place idle around 14:1 (Actual E85 AFR = 9.3:1)
Crusie 14.7:1 (Actual E85 AFR = 9.75)
100-120KPA 13:1 (Actual E85 AFR = 8.6:1)
Full boost 11.8:1 (Actual E85 AFR = 7.8:1)
Remember an 02 sensor is only measuring 02 content and doesn't care what gas you're using. The controller/gauge will convert the voltage to a value which is displayed as your "AFR" so stoich for E85 or Gas will still read 14.7:1
