Hi all,
I am looking for a good brake pressure sensor that works on a 5v power supply. Ranges are 0-10 bar, 0-100 bar (and freedom unit equivalent).
This is for a motorcycle application. I am well acquainted with the AiM sensors but these need a 12V supply.
Currently we are using the FuelTech sensors and have had multiple failures.
Thanks,
I've never had a Honeywell MLH sensor fail and these are a 5V supply sensor.
Any dealer in the US to recommend? I can see that you are based in Australia so this is a long shot.
Honeywell sensors are commonly available from Digikey or Mouser. Google is your friend...
https://www.mouser.com/ProductDetail/Honeywell/MLH02KPSB06A?qs=pLJKYPamQJzqSEthOFnvHw%3D%3D
Other choices from MoTeC USA (Racegrade brand) - note, not 1/8 NPT directly.
https://www.milspecwiring.com/2000-PSI-MOTEC-PRO-SENSOR_p_1591.html
https://www.milspecwiring.com/2000-PSI-DTM-RaceGrade-Pressure-Transducer_p_460.html
+1 for mlh
MLH02KPSB06A
I also found these: https://bf1systems.com/wp-content/uploads/2024/05/ASM-Miniature-08.22.pdf
