Step 2: Trigger Setup
1524 Vistas
Good day,
I currently using a Platinum Pro as my ECU... On my RB26 I have installed the PRP trigger kit. Can I select the from the drop menu the GTR? or Is there a different set up I have to perform? If so, what are they?
Thanks
hello i am presuming it is the 12 tooth model you have brought
i normally remove one tooth from the crank and make it 12-1 and also use the cam sync ( home signal) and settings would look something like the dropbox picture attached
https://www.dropbox.com/s/qzql3na2nij15qq/Screenshot%202021-09-08%2021.26.23.png?dl=0
there is also some great information in this link
https://platinumracingproducts.com/pages/platinum-racing-nissan-rb-ignition-trigger-kit
Regards Ross
Thank you Ross
Peace Brother
