VTEC Issue in H22/h23
1818 Vistas
Hi All,
kindly guide me im seriously into a trouble right now. im running a setup on the following detail
H22 Head ( Skunk2 Stage 2 Complete Head Including retainer spring cam valves everything. the head is even MILD shaved )
H23 Block Stock Block with compression of 210 on 1-3-4 cylinders and 180 compression on 2nd cylinder.
now the issue is that the vtec pull is not engaging properly. i can even upload a map for it which im running right now on it.
i have a drag race in 2 days and seriously messed up.
can anyone help out. plz.
Thanks
Rana
Here's my email Carrolljohn935@gmail.com send me a catalog and everything of the time you have......and have you checked you vtec engage on your ecu?
