Adding a slight curvature to Raychem boots
1157 Vistas
Due to packaging I need my boot to have a slight angle immediately after the connector. I see that 30 degree angle boots are offered but that may be a bit too much. I had planned on the boot being somewhat flexible but after recovering it is quite rigid. Should I recover/epoxy the boot with the wire at the desired angle or is it best to recover in a straight position and then heat the boot while flexing the wire?
Boot is a 202K153-25-0
Thanks!
Recover at the desired angle is best.
