ADVANCE RACE CAR DESIGN, CONSTRUCTION, MODIFICATION, SETUP OVAL TRACK, ROAD CIRCUIT & ROAD
314 Vistas
Recently, I published a book in French on the design, construction, and setup of stock cars for oval tracks and road circuits. It is the only reference in French in the world. It is the result of 54 years of experience in stock car racing, research, and development in Canada and the United States. Very soon, the English version will be published.
It contains basic advice that allows you to recover between 70 and 100 hp lost in the fuel and exhaust systems due to heat under the hood, as well as drag at the rear of the car and on the sides in the low-pressure boundary layer. I teach you: how to cancel lift over the trunk, drag all around the body in the low-pressure boundary layer, and behind the car; how to generate aerodynamics downforce at the rear; how to tune the intake and exhaust so that the gases oscillate together in the intake and exhaust manifolds during the overlap of the intake and exhaust valve openings. Then the exhaust sucks into the intake, creating a natural compressor effect that allows for a power gain of +/- 20% in the range of 50 to 75 hp. Apart from the intake-exhaust tuning, the horsepower gained corresponds to recovered losses. The horsepower gained by tuning is not visible in the dyno tests carried out by the race series officials, because they are carried out with the dyno workshop exhaust system and not those on the car in real conditions of movement on the track. In addition, the conditions in a dyno chamber are different from those in the car on the track. Thus, the officials will not see your advantage. To learn how, you can get my book by contacting me at yvescarol.jean@yahoo.ca or at 1 581 305 1316. The book is an excellent training tool for racing teams.
See the table of contents for the book.
Yves Carol Jean
1137 Route de l'Église, Apartment 611
Quebec City, Quebec, Canada
G1V 3W4
581 305 1316
  • RACE-CAR-DESIGN-presentation-page-frontipice.-and-index.docx
Good day Carol Jean,
Thanks for taking the time to help us understand the availability of your book, please remember to update this thread with information on the release of the English version. All the best with your book's success! Cheers!
