connecting Microtech LT10C to Torque on Android
2259 Vistas
HI All,
I've just had a Microtech LT10C installed in my Miata. I would like to connect it to the Torque App for Android. Trouble is, the LT10C does not have an OBD II port, but only a 9 pin out. Anyone know how to connect the 9 pin to an OBD2?
I'm going to go out on a limb and say you're out of luck sorry. For the torque app to function the ECU would need to support the OBD2 protocol which the Microtech unfortunately does not. You could consider adding the Microtech dash module for a visual display
