Live plot log window
1663 Vistas
Hi
in most of the videos from the course there is a window showing a live plot log. Is this possible to achieve in AEM EMS V2? It would be much easier to have it displayed immediatly and not have to open the logs only after saving them when the car is stopped already
thanks
Live data logging is unfortunately only available in the AEM Infinity, not the V2. You can still achieve the same results but you need to go through one extra step of downloading the log file after a dyno run.
Thanks for the reply Andre. Seems that i must start looking at the infinity as an alternative to the V2.
While it's still a capable ECU, the V2 is getting on a little and newer products make the tuner's life easier. I probably spent half of my tuning career working on ECUs that offered no live plotting of data though so it's still possible to get great results. It just takes a little longer to download the logged data and review it in a separate piece of software.
