RX7 dbw solenoid
1757 Vistas
Hi
At the start of the last webinar Andre was talking about a drive-by wire solenoid from a BMW that was fitted to the RX7. I am Interested to know what items were used in this conversion. As I am doing a build and finding it extremely hard to find a suitable throttlebody to convert my engine to. I will be running this system with a link Fury ECU. would it be a better option to go with the jenvey solenoid . Thanks again for all the help
There are lots of Bosch DBW throttle bodies that can be used, and some are amazingly inexpensive.
Bosch Electronic Throttle Bodies
They're using a unit that is common on BMW S54 engines.
M3 Actuator
If you're just going to go with a replacement throttlebody there're the Bosch units David mentioned as well as all of the GM 90mm throttle bodies. There're a few folks that make adapters for the GM bits, here's one from Full Function Engineering:
FFE GM Adapter
