Should you have a clearance when running a Torrington bearing for high thrust loads?, if so what would you consider acceptable.
What is the application - camshaft thrust bearing on pushrod V8?
I'm more familiar with their use in heavy transport and industrial machinery, where they are always load bearing, but I would expect there to be minimal clearance - a few thou' to allow for thermal expansion and a little more.
Do you have any spec's from the supplier/manufacturer?
V8 dart ls next with Callie’s ultra billet crank, it will be twin turbo drag engine that will see a lot of trans break that puts heaps of thrust load into the bearings and crank. This is my first build with a Torrington bearing so just suss out clearances before assembly.
Where is the bearing being used, it's rather unclear from that? Do you have the assembly guide/manual for the installation?
A spot is machined behind the first main bearing Journal, it’s a common mod for high powered turbo drag engines.
Ah, thank you, always learning :-)
Is the rearward movement limited by a similar bearing between the front pulley and 1st main or is still controlled by the 'normal' thrust bearing?
Can't find much about this, except this - https://www.facebook.com/atomicperformanceproducts/videos/376637966114207 - might be worth giving them a call?
Yes they need clearancing depends on what size crank your running will determine the clearance and few other factors aswell
