4g64 block with 4g63 head
Soldadura TIG práctica
Discusión y preguntas relacionadas con el curso de Soldadura TIG Práctica.
2346 Vistas
Good day gents
Im playing around with the idea of droping a 4g63 head onto a 4g64 block with 4g63 crank. 4g64 pistons and custom length rods.
However i do see that the 4g63 head has at least 2 variants. I assume that is the Turbo and non turbo head.
Is there a substantial diffrence between the turbo and nom turbo head? I would think there is but the evo head costs more than what i paid for the car and also no one has stock. So im considering just getting normal old 4g63 head. Then later sowping over.
If anyone has info i would be greatly thankful.
I understand the difference is in variable valve timing - however, there are some learned people with experience of the different 63 and 64 combinations, if you have a quick search they should come up.
I have never seen NA head that would be the same as turbo head.
You can try 4g63 turbo head from Mitsubishi Airtrek - they are cheaper than Evo. Of course the camshafts will have to be changed for much longer duration for 2.1L destroker.
