Finding injector latency/dead time data
Soldadura TIG práctica
Discusión y preguntas relacionadas con el curso de Soldadura TIG Práctica.
2780 Vistas
Hi guys, I am wondering if there is a place that has data for injectors. either by part number or manufacturer. i know alot of after market (performance) guys supply this info but what about oem's and aftermarket replacement.
You just need to do as much research as possible, if it's a car that an ECU manufacturer has an ECU for then check their base map.
There's also injector rehab's site:
http://injector-rehab.com/shop/lag.html
Or if you're looking for more modern cars then look for a software which can interpret the data on the OE map such as HP Tuners, COBB, ECUTEK etc
Yeah I found that site when I went looking for info. I have been looking for data on 850cc side feed injectors a customer bought for a 1998 sti.
Who makes the ones you've got? You could try starting with the Sard side feed settings from that site
They are made by deleen.
