Coil igniters
Fundamentos de los vehículos eléctricos
1480 Vistas
I’m running an Adaptronic 440 ECU and I’m going to install AEM smart coils. Adaptronic says that I need to run separate igniters since the ECU won’t handle the voltage. Not sure what to use for igniters or where to source them.
Smart coils, by definition, have onboard igniters. Wherever you got your information from, its incorrect.
