Ground after battery relocation to trunk
Fundamentos de los vehículos eléctricos
2701 Vistas
Hi,
Im building a complete new power wiring for the car and also moving battery to the trunk.
Should i ground the battery to chassis only at the trunk or should i connect to plenum/block as well ? (dashed blue line in my diagram)
Thanks,
Paulo
Ground the battery to the chassis close to the battery location. In the engine bay make sure you have a good, short grounding cable from the block to the chassis.
Yes, i did that, but I need to know if I should also have a cable from battery (-) to engine block as well
As long as the vehicle chassis is metal you will not need an additional battery to engine block cable.
