Hyundai genesis coupe tuning
Fundamentos de los vehículos eléctricos
1368 Vistas
Hi,
Anybody was able to tune genesis coupe either using VFTuner or any other solution?
I've been reading the Continental Theta 2 documentation for a while and I'm having a hard time setting up something.
I think it's using a custom version of SimOS (looks similar to SimOS 8.5 from what I found)
Anybody could point me to some kind of documentation that would help?
I have potential customers waiting for me releasing tunes.
I found ignition timing tables (even, though negative timing for crackle seems to create issues (don't judge me on that, I let know the customer the downside but it's still something really appreciated from this crowd))
That's about the only thing I found, even the DTC aren't clear
Thanks
It may help you get a response if you could post the vehicle's year, engine it's using, maybe the transmission, and certainly if you can find and identify the ECU used?
