Sealing grommet
Fundamentos de los vehículos eléctricos
Módulo relevante: Proceso de 8 pasos de HPA > Paso 8: Prueba e instalación final
477 Vistas
What type of sealing grommets do you fellas use? I’ve passed wires through holes with grommets in the firewall before, only to find them loose fitting and worn from vibration and heat.
I have a 2” x 4” hole where the original molex type connectors were on my 70’s dodge ramcharger. My plan was to make a plate and use some type of modern sealed connectors to pass through.
