Twisted screened pair cable
Fundamentos de los vehículos eléctricos
1303 Vistas
I’m struggling to find screened twisted pair cable - most that I’ve come across from my normal suppliers is just screened two core. What brand/model of cable are you using, please?
Thanks
Dave
You can get whatever you might need at IS Motorsports in the UK:
http://www.is-motorsport.com/products/wire_and_cable/introduction.html
Here is the catalog section with info on wire and cabling:
http://www.isgroup-international.com/pdfs/Wire_and_Cable_PDFs/wire_and_cable_catalogue_section.pdf
You probably want 44A0121-22-X/X shown on page 11 of the above PDF
Now, check with them for something that they stock and you can get in less than 300 meter lengths...
Another possibility is Farnell in the UK:
https://uk.farnell.com/c/cable-wire-cable-assemblies/multipair-cable
Thanks David.
Will have a look into those.
