What is the best ECU for Mini Cooper S R53?
Fundamentos de los vehículos eléctricos
2892 Vistas
Just wanted to know which ECU do you guys prefer for tuning a Mini Cooper S R53. Thank a lot! :)
I'm not sure that there are actually too many options. nI've tuned a couple of R53 Mini Coopers here in NZ on the Link G4+ system but I don't know what else is available. Unless you're planning to go wild with mods I'd suggest seeing if you can find a reflash option instead of a full standalone as it's likely going to save you a lot of money.
Thanks a lot, Andre!
