Hello everyone.
can you please help me get the data required to dial in gt r35 injectors into link g4+ platform. A friend of mine wants me to tune his rb25DET neo where he fitted these injectors and i cant find reliable source fo data
What i found is 560cc (570cc in GTR as they run more than 3 bar of differential pressure), and it's 0.890ms @ 13.8 V (14V)
Can some one give feed back on these and if possible more detailed information?
Hello a quick look around the net shows me nothing i think it would be worth messaging tech@linkecu.com to see if they have this info on file
Regards Ross
Thx Ross
I will contact Link
Link advised me to watch motec m1 tutorail. There i found some data, but they looks wierd for me
Flow rate is 11.6 ml/s this equals to 696 cc/min which is not correct i guess, and even if we do correction from 400kPa to 300kPa it results on 522 cc/min which i also not realy correct ) so i'm lost on how to get real flow, think i will use 560 or 570 and see how it goes )
Reference presure is 400kPa (why?)
and i got some lag times from their video
This might Help.
Thx Tommy. It is lag time depending on Pressure VS voltageright?
And what about flow?
All I have is 570cc @322kpa base pressure
You can derive flow at other pressures with that info.
Thx a lot Tommy
Great thanks Tommy
As i will tune engine i will post up here what i ended up with
