Setup sheet
Fundamentos del ajuste del diésel
Discusión y preguntas relacionadas con el curso Fundamentos de Tuning Diesel
2755 Vistas
My I ask where may I find the setup sheet mentioned in this tutorial? Thank you in advance!
Hi Jon, sorry we've had a little issue with the website which I'm hoping will be resolved by tomorrow and the three documents referenced ion the course will be available then. Sorry about that!
Thank you Andre!! I would just like to say great content as always, coming from the hpa platform where I learned a great amount that would have taken me years to compile.
Hey there, the attachment links should be working now. Let me know if you have any more issues :)
https://www.racecrafthq.com/dashboard/courses/motorsport-wheel-alignment/tyre-pressure-keeping-track-of-tyre-pressure-documentation
Taz,
I clicked on your link (above) and then clicked on the attachment link (Racecraft Setup Sheet) and got...
WEBSITE ERROR There has been an error ----------------------- The website server has not been able to respond to your request Contact an administrator: ben [at] racecrafthq [dot]
Am I doing something wrong? :)
Hi Taz,
I'm getting the same error as TerryT.
Same here!
Ahh bugger, I'm doing some more tinkering and testing, sorry about that guys I thought it was solved. I have it working again for me now in a test account so feel free to check again.
I want to check a few more things before I call it a fix this time though, so if it still doesn't work don't panic yet.
In the meantime I have also attached the sheets to this post.
Taz,
Thanks, the original link now works for me. All good. :)
You posted above: "In the meantime I have also attached the sheets to this post." I didn't see the attachment, but guess it doesn't matter now.
Terry
Hmm, OK, another thing on the list to fix in that case. Cheers for letting me know Terry.
