Target AFR/lamda for a Rev 3 3SGTE
Fundamentos del ajuste del diésel
Discusión y preguntas relacionadas con el curso Fundamentos de Tuning Diesel
2013 Vistas
As above what would a sensible target Afr/Lambda for a rev3 3SGTE engine? I'm down to about 0.8 at high revs & 17psi boost but mainly wanting to know how for my 1.0 lamda section should extend up the table.
Hello this table is a good general idea of what i would expect as a base line
Great, that's not to far away from what I've got although yours starts to richen up a little sooner in the load axis which for safety's sake I'm sure isn't a bad thing. Without looking at mine I think I just creeped into boost before stepping of 1.0 lambda.
