Making a signal CSV file from a raw log file and a DBC file.
2865 Vistas
Over the past half decade I've went from not knowing what a CANbus was, to becoming a resource for many market leading companies for information and solutions to challenging problems. Today I am releasing my Log CANverter tool for which I use to create CSV files from a raw CANbus log file + DBC file to compare against.
There's more to come very soon, including Live analysis using MegalogViewer HD, as well as some other tools for analysis and measurement.
https://youtu.be/HvggKjXu4WQ
code : https://github.com/mitchdetailed/Log-CANverter
currently it supports SocketCAN log files, but I have a roadmap for busmaster, kvaser, as well as pcan trc files.
Is anyone have dbc file for Votol EM-150 controller/ ANT bms??If not can I have a complete guidance to create a dbc file??Also I want to know what information I must have from the manufacturer??
