Physical Harness Layout missing
1655 Vistas
Hi,
i'm building the exact same Vehicle with almost the same Setup. If you dont mind sharing your physical layout i'd highly appreciate it.
I'll measure the lenghts nontheless but this would give me a solid starting point.
Thanks in advance.
G'day Felix.
I'm not sure that information would still be around unfortunately, the rope template was transferred to paper, and the template disassembled for another project, and the paper copy never got digitized sorry.
Hi Zac,
thanks for the Reply.
Any Pictures of the finished and installed Harness would also help to speed up the layout process.
THanks
