E11V2 Haltech ECU
Fundamentos del cableado EFI
1756 Vistas
Hey
Quick question. I have an old E11V2 Haltech ECU, My question is, there is a map where you can add an AFR target. Which can be used for auto tuning. How and what type of O2 sensor would I have to use. Can a wideband O2 sensor like LSU 4.2 work (Innovate brand)? I am new to this tuning stuff. Do I need to add another controller or just use the controller that comes with the sensor.
I have added a wiring diagram of the E11v2 ECU if this helps. THANKS
  • E11V2-AUTOSPEC-Wiring-Diagram.pdf
