Reliable Tool Suppliers
Fundamentos del cableado EFI
1475 Vistas
Hey guys,
so im from an aviation background and working my way into milspec wiring for my race cars. Now I am use to using the tools at work and I’m looking for some mid ground tools to use at home.
Is there a supplier you use or certain brands you stick to? Currently after the following
lug crimpers for up to 25mm2 wire
wire strippers ( I have found the ones in your video)
closed barrel and open barrel pin crimpers
please if you could post the link with a few key words in it so this post may be easy to find for others that would be great.
You will some decent suggestions in this post: https://www.hpacademy.com/forum/efi-wiring-fundamentals/show/course-tools-and-materials
Edit, tried the link in various formats, but this forum software messes it up for some reason? Copy and paste the link into the address bar and it should work.
