Webinar 184 Ghost Cam
Fundamentos del cableado EFI
1642 Vistas
Quick question? Is there anything in particular to look out for or to do differently in a manual equipped vehicle? Thank you!
I actually can't recall setting up ghost cam on a manual car as I'd say that 8/10 GM vehicles I tune are auto. The principles are exactly the same but I can't recall how the distinction is made between P/N and drive. I suggest you try what was detailed in the webinar and then see how the car responds.
Thanks Andre!
Hello Andre Ghost cam can be done on a ls v8 with link g4+ ecu .in the idle ignition table ?
