Wiring worklights
Fundamentos del cableado EFI
1069 Vistas
To wire worklights on a heavy machine should I run a fused wire adhering to the required specifications to a relay and then the relay to a switch positioned in the cab and then the other poles on the relay will power the light?
Still unsure of how I would ground it especially if I am mounting 3 lights one after another
