Mitsubishi EVO 6 4G63 bearing choice
Instalación y configuración de PDM
1178 Vistas
Hello,
i am building a 4G63 engine for a street used EVO 6 (Target Power 450HP@ crank).
What brand and type of bearings (Main and Rods) would you recommend / prefer for that kind of usage?
Thank you for your help
I always use OEM bearings except one time when I used King rod bearings that came with aluminium rods as a package. The reason being is that ACL bearings give you quite big coearance, more than needed for that level of power.
Thank you for your feedback
