B6 A4 1.8t quattro
Ponderación práctica de esquinas
Discusión y preguntas relacionadas con el curso Rincón Práctico Ponderación
1145 Vistas
This car has been the primary obsession of mine for nearly 10 years, and the mod list is testament to that.
Engine mods: Mahle powerpak pistons, IE forged con rods, large port AEB cyl head with Ferrea valves, Supertech springs & retainers, IE race cams, Full-race T4 twin scroll turbo manifold, Borla catback, .92 a/r EFR 8474 turbo with Turbosmart twin port IWG actuator, 4 port MAC valve, Tial Q BOV, 82mm Bosch throttle body, IE -8an fuel rail, IE surge tank with twin AEM 400's, Walbro 450 in tank pump, custom -8an fuel lines, Aeromotive -8an AFPR, Snow Performance multi pump relay module (until I get a PDM), Injector Dynamics F750 fuel filtration system, Evolution Racewerks competition FMIC, P-Motorsport intake manifold, Newsouth phenolic spacer, Vibrant -10an catch can, FIC 1200cc injectors (for now), Fluidampr, IE manual timing belt tensioner, IE billet timing gear, IE adjustable cam pulley, Stern motor mounts, and probably more that I can't recall.
Software & additional sensors: Ignitron ECU, turbo RPM, EGT, ethanol content, oil pressure, and an AEM MAP sensor in the manifold for speed density tuning.
Driveline: 01E 6mt (originally from a C5 A6) built with JHM carbon synchros, upgraded shift collar, 4:1 center diff, Ringer Racing 240mm clutch & lightweight flywheel, JHM "trio" short shifter kit, JHM limited slip rear diff, Apikol rear diff mount, 034 trans mount, stainless braided clutch slave hose
Suspension / brakes: Bilstein PSS9 coilovers, Verkline tubular front subframe, Meyle HD front & rear control arms + tie rod ends, 034 adjustable rear sway bar, 034 front & rear sway bar end links, Brembo 17z front calipers, B7 S4 rear calipers, Rotorlab 330mm front rotors & 300mm rears, stainless braided hoses, Hawk HPS 5.0 pads
Interior: platinum heated Recaro seats from a B6 S4 dyed tan to match my interior, Kenwood touchscreen radio, Kenwood 1800 watt amp, 2x 12" Alpine type S subs, B7 center console swap, dash mounted cup holder replaced with euro card tray & custom buttons, oCarbon carbon fiber trim, ECS Tuning vent mounted boost gauge, CJM Industries dual gauge pod, Full-race turbo speed + oil pressure gauge, Prosport EVO fuel pressure gauge, custom billet stainless steel shift knob, hardwired AC/DC inverter, and battery relocated to the trunk in a custom compartment where the stock spare wheel was kept
The short term goal is to get a HP8440 PDM from rywire, and convert the majority of my electronics to run thru the PDM.
The long term goal is to swap the engine to a fully built BCY 4.2T from a C5 RS6, and run that on a different standalone. I already have the 4.2T, and I'm in the process of building that. I have Pauter forged con rods, and cylinder heads from a D2 A8 4.2 40v. These 4.2's use a belt driven timing system & port injection, so they aren't susceptible to the same timing issues that plague the chain driven B6 & B7 S4's, and fueling upgrades are easy & cheap compared to the later direct injected 4.2's.
