Obd1 p72 Intake air temp wiring
Ponderación práctica de esquinas
Discusión y preguntas relacionadas con el curso Rincón Práctico Ponderación
447 Vistas
Does the ground for the iAT need to be spliced into the sensor ground for the iAT on a Honda b series obd1 ecu or where does go?
You got it. 2 wire IAT sensors have signal and sensor ground wires, and don't get run to power ground or power.
