Difference in MAF scaling steady-state
Preguntas del seminario web
987 Vistas
Hello,
After learning the practical reflashing course and following the Ecuflash videos, i started gathering data for my MAF rescaling. However when i do my 2000rpm run (lower then my Engine Load Compensation peak) i have -2% total trim. But when i do my 4000rpm run my total trim is +5%. When i do my WOT run it's around -1% until the end of the run it starts creeping up till -3.5%. Only thing i can think of is: i did my 4000rpm run after my WOT run and thus my ECU was reset. Do i need to drive more before doing another steady-state run?
Thanks,
Tom Neuteleers
  • 07-Legacy-2000rpm-Steady-State.csv
  • 07-Legacy-4000rpm-Steady-State.csv
  • 07-Legacy-WOT-Run.csv
