Innovate LM-2 usage with HP Tuners
Preguntas del seminario web
1568 Vistas
Quick question. Do you have to install an additional bung in each of the cars tuned or is there an output from the LM-2 that feed info to the ECU? Watching all the worked examples I find it hard to believe that they are welding a bung in each of the cars, even in stock form (IE, Practical Reflash Tuning - HP Tuners Holden Basic). I figure if you already go catless you could install in the post cat bung and disable those DTC's but in a vehicle with cats wouldn't the O2 reading be affected post cat?
Just trying to find out because I just ordered my MPVI2+ and am about to order the LM-2 and want to know what to expect.
Thanks in advance.
Hello, I do install bungs (all ways have ) to be honest, I have done it ever since I had a car with removed cat internals give me an issue with fluctuating readings, my thoughts on this was it was caused be some sort of turbulence. the mpvi2 has a plug come with it as does the Lm-2 that allows you to connect them together
Regards Ross
Thank you Ross. Another question. The LM-2 can be bought as either a single or dual, basic or complete kit. Would you recommend the dual kit (for instance with a V8) or do you only run one AFR signal into the MPVI2?
Also I see the main difference between the LM-2 basic and complete kit seems to be that the basic kit doesn't come with the analog in/out cable, ODB-II/CAN interface cable or SD memory card. I assume at the very least I would need to get the analog in out cable to interface with the MPVI2. What about the OBD-II/CAN cable?
Thanks again
