Ignition coil trigger wiring.
3555 Vistas
Hello all
Below is a direct quote from the AEM infinity 6 pin out. Please help me understand the warning in the notes about not connecting to the coil primary. When I look at wire diagrams included in the AEM manual it looks like they wire directly to the coils in many of their examples.. I'm confused. Do I need a CDI or igniter or not?
I will be connecting to a J series 3.5L Honda 2003 with coil on plug ignition.
C1-13 Coil 2
25 mA max source current
0-5V Falling edge fire. DO NOT
connect directly to coil primary. Must
use an ignitor OR CDI that accepts a
FALLING edge fire signal.
You NEVER connect directly on a coil primary.
If it's a "dumb" coil, you NEED an igniter.
If it's a "smart" coil, you can connect directly to the input pin of the coil. ( the igniter is embedded in the coil)
Now, you have to figure out if you have "dumb" or "smart" coils.
For what I found the J35A(4/5) seems to use "smart" coils.
Pin 1: +12V (round edge)
Pin 2: ground
Pin 3: Signal (clip) <- connect here
http://aemelectronics.com/files/instructions/30-7106%20Infinity-6%20Hardware%20Specification.pdf
Thank you so much! big help for this Webber and coil/points guy. (leaving my barometer and altitude density kit at home now).
Pete
