05 Pontiac gto hitting rev limit at 5700
Ajuste práctico independiente
Módulo relevante: Conceptos básicos del flasheo > Conceptos básicos de Reflash > Límites de par
678 Vistas
I have an 05 Pontiac GTO that went from a stock LS2 to a ls next dart block with a 4.125 bore making about 600 hp at the crank tuner can’t seem to find out what the problem is it has the stock maf On it but keeps banging off the limiter at around 5700 cannot figure it out any help would be great, And yes try to bump the rev limiter up to 7200 but it will not do it
You're not giving a lot to work with.
Other than the short block (?), what else has been changed - head and valve springs, camshaft, engine management , anything else?
What are you using to tune it?
The greater the information you can give the better. For example, is it a hard cut? Is it at the same rpm regardless of load and gear?
Sorry Gordo I haven’t been on here in a minute but yes ported LS3 heads 388 in.³ engine cam headers engine made 600 hp at the flywheel, and yes hits limiter in every gear right at the same RPM Definitely banging off the limiter, Local tuner tuned it I was with him and turned it on the road tried everything using HP tuners still nothing just like injectors being cut out it 5800 RPM
David we really need more info. Calibration and datalog could help too.
I'm having the same problem with my 05 GTO. Too many modifications to list but acts like the limiter is set to 5700 and its not?
Lots of guesses -- MAF maxed out? Injector duty cycle protection? Some torque table limit?
