best oil scavenge pump for low mount turbo
Ajuste práctico independiente
2615 Vistas
Hello,
What is your recommendation? I preferer mechanical scavenge pump for turbo oil return if there are any
"Best" is going to depend on many factors, none of which you've provided...
I'm also curious what people are running for both potential FD3S and a wrx.
Sorry , I meant best in reliability.
i use a scavenge pump from a bmw m5. they use them to scavenge the oil from heads in high g corners... i have to check the part number..
