EVO 9 with Haltech platinum pro pnp doesn't start
Ajuste práctico independiente
71 Vistas
Hello guys,
So after putting in the new parts I reset the ecu and loaded the original evo 9 map from haltech i just changed these parameters (injector deadtime and flow rate, also lowered the cranking injector time) so mostly stock evo 9 file trigger angle is also 76 deg which is common on EVO9. at the beginning it wasn't reading the rpm but, I changed to a new intake camshaft position sensor and I attached the log from several start attempts. is it still the sensor issue? because it is reading rpm but on the data log Home counter at miss is fluctuating -1 to 0 to 1. I would really appreciate it if someone could help me out here I can even attach the tune file if needed.
  • s9.csv
