HP Tuner Missing Vital Tables
Ajuste práctico independiente
Módulo relevante: Ejemplos resueltos > HP Tuners GM Gen V LT - Ajuste basado en el par > Paso 3: Configuración del archivo de ajuste base
376 Vistas
While watching the video for the base tune setup for the 2019 Cadillac, I have found that most of the tables shown in the video don't exist on my HP Tuners. Many of these tables are vital in some situations, such as if the engine has been overbored. I've included screenshots demonstrating the differences I'm seeing. I've come across this before, but not nearly to this extent. I mean, if a Cadillac shows up in my shop one day, I can't make many of these adjustments shown in the video.
I am using the tune included with the course (both stock and final are affected.)
I have the latest HP Tuner installed. Is there some different level of HP Tuner that I need to be able to access to see these tables?
I don't have that specific file to check and confirm but my suspicion is that you have the software in 'basic' mode which hides the majority of the parameters that are available. You can change to 'Advanced' mode under the 'Edit - View' menu.
Andre,
Thank you! That was exactly the problem! Now I can see everything the same as in the video! Thank you again!
