Afr logging 6.7 powerstroke
1243 Vistas
Have a 2013 f450 6.7 with new engine. Would like to monitor afr and egt so I can combine with stock ecm . Would like to write program while on the dyno. Looking for an electronic display versus all analog gauges up the post.
Thanks Michael
Michael,
While logging your truck with HPTuners, go ahead and right click on the PID list to add channel. If you search AFR from there you can see most of the compatible AFR setups which can be integrated into HPtuners software easily. Most are electronic readout as well.
Hopefully this is useful,
Nick
