Honda Civic turbo-track build
3566 Vistas
So I'll try and keep this short and on topic of tuning/engines.
I bought the car as a standard b16b(n/a) engined car with the plan to turbocharge the stock engine.
This worked fine until a mishap with a t-piece melting shut between laps of the Nurburgring, this lead to zero boost control the next time I hit the throttle so you can imagine what happened next....
So the rebuild began, I'd never rebuilt and engine before so massive learning experience, had a few hiccups with oil pumps. Basically I wasn't being clean enough with the build process.
Got there eventually and the current forged build has been running 2500miles and a good few track days without fault.
Basic specs of the engine
1817cc
B18c crankshaft
Manley rods and Wiseco pistons
9.96-1 cr
Standard b18c head
T3/T04e turbo on a cast manifold and 2.5" exhaust system
When I had this tuned it made 350@1bar of boost.
So ran like that until recently I found the bearings in my current turbo are past their best, cue upgrade!
New manifold, gtx2867r and 3" exhaust going on with new engine management(hondata s300 v3)
So this is what brings me here, tuning this setup on the s300 then eventually on to tune others.
A couple on track shots
So that's where the cars at ATM, it's away having a cage welded in and the 3" exhaust fabbed up. Then it's tune time!
Sounds like a lot of fun on track.
Just curious, how did you choose your CR, ~10:1 seems quite high :)
Yeah it's standard practice in the Honda scene to run that high on a turbo motor. Unless your aiming for massive figures.
I wanted to keep decent drivability off boost and for my power goals 10-1 is fine.
The stock b16b I ran is 10.8-1cr.
For sure, having decent off-boost response and fuel economy is always nice, should help with spool too.
Since E85 is non-existent in the UK, I guess you will be using 98 pump fuel?
Yes just normal pump fuel.
I'll experiment abit but Shell Vpower is where I'll start.
Nice built and nice car . But I am surprised you aren't using a block guard or sleeves . Also I am curious why you didn't use the B16B head ?
When I built the engine I was only expecting to run around 350-400hp.
The cost and finding someone over here that's reliable enough to either sleeve or fit a block guard are the two main reasons I didn't bother.
The b16b head had a lot of swarf and crap in it from the piston failure so I opted to use a b18c head.
Little known fact that the uk spec dc2s and 98spec JDM dc2s have the same head as a b16b(3degrees more duration on intake cam over 96spec b18c) so in effect I've lost nothing.
Do they also have the same valve angle ? Cause the B18C and the B16A have the same but the B16B has a better chamber in general , hence my question .
As a Honda enthusiast , if you do not mind me asking , what also have you done ?
As far as I'm aware they are the same.
I'll make a list of parts etc on the car when I get home from work.
So this is the spec list I sent the insurance company last year, I've been updating it as parts have been added.
Note manifold, turbo and exhaust are being replaced this week and a 6point msa spec cage has just been welded in.
M20EKR
Civic Type R(EK9) Turbo
Engine:
B16b block bored/stroked to 1817cc
B18cr crankshaft from Integra Type R
Manley forged connecting rods
Wiseco forged pistons 9.96-1cr
Honda headgasket
B18c4 flywheel
RPC stage 3 clutch
Walbro 255LPH fuel pump
Standard b18c cylinder head
Hondata 4bar map sensor
Injector dynamics 725cc injectors
Apexi avcr electronic boost controller
Go-autoworks street turbo kit with turbonetics t3/t04e turbo and intake filter kit add ons.
Tial MVS wastegate and Tial dump valve
2.5" stainless steel exhaust system(turbo back)
Front mount intercooler
Heat taped boost piping and intake piping.
Breather ports in block and cam cover to single oil catch can
Chipped p28 honda ecu
25row Mocal oil cooler
Tegiwa DC2 aluminium radiator
3 power levels
260hp @ 0.4bar
310hp @ 0.7bar
350hp @ 1.0bar
Chassis:
Cusco zero 2 Coilovers
Hardrace front camber arms
Hardrace roll centre adjusters
D2 rear camber arms
Wedsport tc05 track wheels
Dunlop direzza dz03g semi slicks
S80 gearbox from 98spec Integra Type R
Kazz 1.5way Limited Slip Differential(Plate type)
Carbon lorraine rc6 brake pads front
Hawk DTC-60 rear
Brake master cylinder brace
Aircon, ABS and Power steering removed
Tilton brake proportioning valve fitted with new hardlines throughout
Rebushed suspension arms half poly half hardrace rubber
Exterior:
Varis carbon-fibre bonnet(colour coded to match the car)
ProCarInnovations side skirts and rear diffuser
Chargespeed replica front lip/splitter
Interior:
Pair of Recaro SPG bucket seats(FIA approved but out of date)
4 Point harnesses(FIA approved)
OMP WRC steering wheel mounted on HKB boss
AEM wideband AFR gauge
SAGA oil temp gauge
Stack oil pressure and water temp
Majority of interior stripped out
Nice and interesting built .
Have you also changed the final drive to a 4.4 , or kept it stock 4.7 Type R spec ?
The standard gearbox in these is an s4c LSD which has the same ratios as the 4.4 s80. I've got the 4.7s80 from 98spec dc2 in this ATM.
