Lexus is250
1764 Vistas
Hi,
I am doing a 2jz swap to my 2006 lexus is250. I want to get wheelspeed sensor via a can into my haltech elite 2500 in order to activate launch cotrol system. Is it possible ? What is the way to do it ? If there is no possible way, What is the solution ?
Unfortunately the CAN input into the Haltech isn't user definable so there's no way to use the CAN based wheel speed inputs. I'd suggest adding a speed sensor to the driveshaft and wiring this to the Haltech.
what about transmission speed sensor input to the ecu? plausible?
