Air Fuel Ratio
Sistemas de plomería para deportes de motor
Discusión y preguntas relacionadas con el curso Sistemas de Plomería para Deportes de Motor
1191 Vistas
Hi, so if tuning with lambda is easier why not many tuners do this? Because sometimes there´s no need of using e85 or other fuels? And is lambda the same as using an A.F.R gauge?
There may be two main reasons - it's what many 'tuners' will be familiar with, having been brought up on petrol/gasoline, and many gauges being calibrated for petrol/gasoline.
Getting used to lambda is a good idea, IMO, as it's consistent regardless of the fuel used - 1.0 is stoichometric, chemically balanced, 1.0 is leaner.
Sort of, the actual value is in lambda, converted to AFR - FOR THE SPECIFIC FUEL IT'S CALIBRATED FOR!
