hp tuners question
Sistemas de plomería para deportes de motor
Discusión y preguntas relacionadas con el curso Sistemas de Plomería para Deportes de Motor
1352 Vistas
How do i add eq actual into hp tuners channels charts v time
to be fair i havent used the software enough, but next week i will be spending a few days with it to learn all i can
i found this on the hp forum i hope it helps
Channel -- Transform the WB to lambda so it is EQ Ratio sensor pick Equivalence Commanded channel Chart -- Select Equivalance Ratio Commanded by (Generic sensors > Engine > Fuel > Commanded/Desired), Select Air/Flow Ratio (sensor) by (Generic Sensors>Engine>Oxygen Sensors>Air/Fuel Ratio) and select AFR Error (Math) by (Math>Lambda & AFR>EQ Ratio Error)
Regards Ross Update -- Make sure all sensor/sae and units designators match throughout the Channel, Chart, Math and Graph flowEd M
