AEM EMS-4
1703 Vistas
Hi,
Anybody have any experience (good and bad) with the AEM EMS-4?
I install it on my car and all I can find it trouble all over.
The harness wiring is incorrect.
The tuner software doesn't work and in general everything the spec stated is incorrect.
Already purchase it and would like to use it.
After solving many problems, I have spark and the engine will run only with carburetor spray.
Tthe injectors impedance is 9.9Ohm.
The spect claim 8-14 ohm should work.
I don't get any fuel.
don't have pulse for the injectors, 13.2V measured on both pins.
any suggest will be appreciated.
it's Honda K24A3 Engine
