Ecu pinout
1815 Vistas
Hello,can somenone help me with pinouts for Alcatek ECU for Impreza 97? I want to install a wideband O2 but don't know the pin. I try to contact Alcatek support but no reply.
Is this a plug in play ecu or a wiring in system?
Can you post photos of the connectors?
It is a plug and play Ecu. I already find the pinouts. If anyone is interested the pinouts are the same as Simtek Ecu and could find them here http://www.simtek.co.uk/download/ecu-pinouts/
Also the Als and LC pins activations are the same.
