Need Help with Sweep - It's Rendering Incorrectly with a Guide Rail
820 Vistas
Hi,
For designing the tube with a flare in one section (the 'Sweeps and Piping' lesson), I am trying to use the sweep tool with a guide rail. It rendered correctly once somehow but, now it only renders the flare correctly on the side with the guide rail. What do I need to do to fix this issue without having to create a guide rail on the other side of the path? (file attached showing one side distorted)
Edit:
In playing around with it, even though the points are tangent where the flare is, if I make a slight change to the first curved line (from the profile) that's on the guide rail, the issue goes away. Why does that change fix the issue?
  • Intake-Sweep-v2.f3d
Hi Joe, See the screen recording I attached.
Probably not the answer you're looking for, but it turns out this depends on the shape of the guide rail, and since this was really just a basic demo of the idea with no dimensions on that part of the curve, it's easy to do something a little different and get a different result. Long story short, don't stress it, you're model was perfectly fine.
I think the reason is, the curve in your model just went past 90 degrees slightly, so I smoothed it out a tad and it fixed it. Hopefully that all makes sense.
  • sweep-.mov
