Piston stop
Módulo relevante: Habilidades prácticas > Lectura de una rueda de grados
967 Vistas
My engine is the Honda d16 can the piston stop be used or the dial indicator is better suited to find true tdc
Different people may have different thoughts.
With a degree wheel the stop is easier, if going by the timing marks, a DTI may be easier.
I don't think it makes any difference. I most times use a dial indicator since I have it out to check cam timing. Just make sure the contact point on the piston is centered on the pin that connects the piston to the rod.
