Tuner Software for BMW E92 M3
2888 Vistas
Hey y‘all
I am looking for a tuner software for the stock E92 M3 (S65) ECU.
At the moment i use Dimsport with a modified map editor, but for Racecars and Super charged its not the best, because some tabels are missing.
A good datalogger is also rerequired, because the standart OBD dates are not sufficient.
Of course i can use the Haltech Elite 2500 with a custom can loom, but at the moment for manual cars only. For the DCT ones, the Syvecs pro plug in. But in some VLN-Raceclasses is it not allowed to change the ECU.
Does anyone a other tuner software for these nice high rev V8 Supercars?
Greetings Marcel
im in the same issue as you spent money and no actual good tunning software solution we can even partner and pay for a good definition development for a software like tunerpro or something wwe can really tune properly i have a big bore custom cams supercharged m3 e92 and im running un ess tune and its not running perfect
