2JZ trigger setups
Fundamentos del ajuste de EFI
438 Vistas
Hi guys,
I’ve recently started digging into ECU tuning basics (I also picked up the Practical Standard Tuning course from you, just getting into it).
I was going through some old MaxxECU files I have for different 2JZ cars and noticed something that confused me a bit. In the trigger settings, one of the setups is using Falling, while another one is set to Rising, but both cars were running perfectly fine.
How is that possible? What usually determines whether Rising or Falling should be used on a 2JZ in this case?
Thanks!
