AF ratio to Lamda
Fundamentos del ajuste de EFI
1920 Vistas
What is formula for AF ratio to Lamda?
Depends on the fuel and altitude.
For petrol lambda 1 equals about 14.5-14.7 AFR, so the elaborate formula you need to apply will be Lambda = AFR/14.7
