AFR
Fundamentos del ajuste de EFI
Módulo relevante: Cómo funciona la ECU > Cálculo del flujo másico de combustible
837 Vistas
What if the AFR is 12:3
12.3:1 AFR is very close to most efficient spot (12.6-12.8) yet safe enough to run at high loads for NA engine...
For forced induction engine this number is too lean unless very high octane rating fuel is used and boost level isn't big (up to 1 Bar maximum)...
